Home Forums Product Discussion & Questions BeoGram Beogram 1000 cable
  • #65305
    swo
    I restoring 3 Beogram 1000.ย  The original Signal cable has two Audio return shields and one Ground” “Chassis Ground” “Shield”.ย  It looks like this cable is never available. What cable should i use and how to mount.
    thx Wolfgang
    #65321
    Mark-sf
    Assuming it does not have a phono preamp board, it depends on what input you are connecting to. If you are going to a DIN Phone input, you need a 5-pin DIN cable. If you are connecting to an RCA phono L/R jacks, you need a shielded pair plus a separate chassis ground wire.
    • This reply was modified 2 hours, 37 minutes ago by Mark-sf.
