Home Forums Product Discussion & Questions BeoCord Beocord not rewinding or forwarding – here is a solution
Viewing 8 posts - 1 through 8 (of 8 total)
  • #40922
    69er
    Hi guys,
    wthout this forum i could not maintain my B&O hobby, so first of all thank YOU all for the help in the last years!
    You should always give back – so here I am.
    I struggled a lot with some Beocord 6500 and similar (one large belt drive).
    Most often i was healed with a new belt – but even sometimes with new ones, it did not work well. Especially the fast forward and rewind function was not good.
    My background is engineering – not that i know, how electronics work – but as engineer you most often don´t give up that easy if an error occurs. And you don´t believe immediately, if it suddenly works and You don´t know why.
    So: i found ONE error, for sure not the only one, but the one, which was important for 4 of my beocords.
    It was not the belt, it was the little white drive worm on one of the motors.
    Look at yours, and when you see a little crack – this is it. It slips then on the shaft. And this stops the whole B&O mechanism.
    You need to dismantle the whole piece, clean it with alcohol and the glue it with superglue. Not the slipping  stops and the mechanism works how it should.
    Of course, cleaning all other stuff and replacing belt is a must, but if it´s not enough – maybe this one is the last step before success.
    Happy!!!!
    Wish You all a pleasant nicht
    69erIMG_9088IMG_9087IMG_9089IMG_9090
    #40923
    Jonatan
    Found this post now. Trust me I WILL check this!! Really good post. I hope this helps me and my beocord. I will get back with results!
    #40924
    Jonatan
    Didn’t find any cracks there. Have to check some more.
    #40925
    citronix
    Thanks a LOT – been trying to find the fault on my Beocord 5500 for ages – but coudnt until i red your post
    #40926
    69er
    happy to help
    #57623
    sverreh
    Thank you! I have a Beocord 4500 with similar ff/rew symptoms, solved when I found this posting. Initially I did not see the crack in the worm gear, but after a closer inspection and ultrasonic cleaning of the gears it became visible. I assume that there are no alternatives to glueing the worm gear to the shaft?
    Sverre
    kknyc
    SILVER Member
    thank you for this post! Im going to check this as new belts didnt solve my issue
    • This reply was modified 2 months, 3 weeks ago by kknyc.
    H Casey
    This is fantastic advice, I’m going to go home and take a look at my Beocord 5000 after work and check whether this helps, since I’m having a lot of intermittent issues with it!
    Even if it doesn’t fix my Beocord, thank you so much for letting us know! I appreciate the work you put into identifying this problem and the care you took in putting that information in a place where others can refer to it and learn!
    • This reply was modified 2 months, 2 weeks ago by H Casey.
