Home › Forums › Product Discussion & Questions › BeoCord › Beocord not rewinding or forwarding – here is a solution
- This topic has 7 replies, 6 voices, and was last updated 3 months, 4 weeks ago by
H Casey.
21 November 2022 at 12:08 #40922
69er
BRONZE MemberHi guys,
wthout this forum i could not maintain my B&O hobby, so first of all thank YOU all for the help in the last years!
You should always give back – so here I am.
I struggled a lot with some Beocord 6500 and similar (one large belt drive).
Most often i was healed with a new belt – but even sometimes with new ones, it did not work well. Especially the fast forward and rewind function was not good.
My background is engineering – not that i know, how electronics work – but as engineer you most often don´t give up that easy if an error occurs. And you don´t believe immediately, if it suddenly works and You don´t know why.
So: i found ONE error, for sure not the only one, but the one, which was important for 4 of my beocords.
It was not the belt, it was the little white drive worm on one of the motors.
Look at yours, and when you see a little crack – this is it. It slips then on the shaft. And this stops the whole B&O mechanism.
You need to dismantle the whole piece, clean it with alcohol and the glue it with superglue. Not the slipping stops and the mechanism works how it should.
Of course, cleaning all other stuff and replacing belt is a must, but if it´s not enough – maybe this one is the last step before success.
Happy!!!!
Wish You all a pleasant nicht
69er
23 February 2023 at 13:36 #40923Jonatan
BRONZE MemberFound this post now. Trust me I WILL check this!! Really good post. I hope this helps me and my beocord. I will get back with results!
26 February 2023 at 17:47 #40924Jonatan
BRONZE MemberDidn’t find any cracks there. Have to check some more.
7 November 2023 at 17:05 #40925citronix
BRONZE MemberThanks a LOT – been trying to find the fault on my Beocord 5500 for ages – but coudnt until i red your post
30 November 2023 at 23:29 #4092669er
BRONZE Memberhappy to help
25 July 2024 at 13:31 #57623sverreh
BRONZE MemberThank you! I have a Beocord 4500 with similar ff/rew symptoms, solved when I found this posting. Initially I did not see the crack in the worm gear, but after a closer inspection and ultrasonic cleaning of the gears it became visible. I assume that there are no alternatives to glueing the worm gear to the shaft?
Sverre
9 December 2025 at 13:33 #71830kknyc
SILVER Memberthank you for this post! Im going to check this as new belts didnt solve my issue
12 December 2025 at 00:17 #71862H Casey
BRONZE MemberThis is fantastic advice, I’m going to go home and take a look at my Beocord 5000 after work and check whether this helps, since I’m having a lot of intermittent issues with it!
Even if it doesn’t fix my Beocord, thank you so much for letting us know! I appreciate the work you put into identifying this problem and the care you took in putting that information in a place where others can refer to it and learn!
