Home › Forums › Product Discussion & Questions › BeoCord › Beocord 9000 – keypad not responding
- This topic has 5 replies, 2 voices, and was last updated 10 months, 2 weeks ago by
baek47.
1 May 2025 at 09:30 #65400
baek47
SILVER MemberI bought a Beocord 9000 and did various repair – but it is not responding at all activating buttons on the keypad panel.
I powers up and I and there is light in the dispay + cassette drawer.
All belts are changed and capstan is running.
All leafspring concats looks good.I can meassure the -24, 24, 32, 13 volts on the board 6.
I can also meassure 6.2 and 5 volts on the board 1 – didnt check all testpoints here.But looking at P21 wire 3 in the servicemanual it says 5.5 Vp and shows some kind of pulse or AC curve.
The P21 wire 3 only feed the IC1 (input/output expander) pin 38 texted 50/60hz.Meassuring P21 wire 3 I have:
1,6v DC and 0,7v AC connected to the board 1
2,7 DC and 1,7v AC no load
My very bad usb oscilloscope shows nothing….Could this be my problem?
Best regards baek47
1 May 2025 at 10:03 #65402baek47
SILVER MemberI also recapped all brown/orange ROE capacitors.
I replace the 4.7v zener before the P21 wire 3.1 May 2025 at 10:03 #65403baek47
I replaced the 4.7v zener before the P21 wire 3.15 May 2025 at 11:56 #65609baek47
SILVER MemberI tested the P21 wire 3 with an oscilloscope. There is 5.5 v ac according to the servicemanual. Good – but the problem is still there….
Changed some transistors…no change.
Checked thoroghly the keypad is working.
Changed more capacitors…no change.
Resoldered a number of multiplugs….no change.
Took the motor apart again….no change.
Tested thoroughly all contacts on motor….The symptoms are:
When i connect to power, the capstan starts running…
I can not put it into StandBy…
Keypad not responding whatsoever…with or without cassette inserted…And…….when connected to power the lamps “Fe”, “Metal” and “Rec open” are lit, the “Cr” and “No store” are not – no matter whether a cassette is inserted or not..
Anybody have an idea where to look?
Br baek47
29 May 2025 at 07:49 #65894Dillen
ModeratorSome versions have a fuse on the display board. Have you checked?
29 May 2025 at 09:18 #65909baek47
SILVER MemberHi Martin
Yes, it is good and the IC1-3 are getting 4,8 v.
I also checked that I have continuity on the display board when activating buttons on the keypad.Since my my last post I changed all transistors (and caps) on the “display board 1” and the “digital/analog converter board 11” – no change except that the “rec.cal.” on the display board isnt lit anymore. And resoldered almost all joints as well….
By the way, my model is the first, below 2831001.
Next I will go through the Osc. board 13 and Rec/ampl. board 3….but advices are welcome
Regards Torben
