Home › Forums › Product Discussion & Questions › BeoCord › Beocord 5500 will not stop
- This topic has 6 replies, 4 voices, and was last updated 2 years, 11 months ago by
Glitch.
8 April 2023 at 03:20 #45609
herrit
BRONZE MemberI have just replaced the two belts within my Beocord 5500 and powered it up. Both belts seem to be doing their job. When I press Play, FF, RWD & Turn on the main keypad the cassette transport mechanism does what one would expect, and the tape goes in both directions. If I press the Play button on the fascia it starts and stops. (The drive pins continue to rotate for ~4 seconds).
But … if I press Stop on the main keypad, whilst the tape mechanism stops & the pinch rollers retract, the drive “pins” do _not_ stop rotating, unless I press Play on the fascia twice, and/or turn off the power.
So it looks like the Stop button on the control panel is only activating the head & pinch roller retraction, and not stopping the drive motor. I have undone & re-seated the ribbon cables, & I am 99.9% sure they are good. I never needed to remove the ribbon cable that goes to the main control panel, so I can’t see how I could have mucked that up.
Any ideas? Whilst I have downloaded the Service Manual, interpreting the electrical diagrams is beyond my pay grade.
Many thanks!
12 April 2023 at 21:24 #45610 filip_kbhBRONZE MemberNot sure what you mean by “drive pins” … a picture?
13 April 2023 at 04:43 #45611Glitch
BRONZE MemberI assume that you are asking about the capstans?
I’m not familiar with the BC5500, but on other Beocords the capstan turns whenever the deck is not in standby.
Glitch
13 April 2023 at 10:36 #45612herrit
BRONZE MemberSorry for not being clearer. By “drive pins” I mean did mean the capstans, yes – I had thought that the capstans were the plastic “gears” that go through the centre of the cassette. My bad.
- When I turn the deck on the capstans (and flywheels below etc) are stationery
- When I press PLAY (on the slide out control panel or front panel or Master Control Panel) the capstans rotate & the tape plays
- When I press STOP on the fascia the tape & the capstans stop. (The capstans actually continue to rotate for ~4 seconds, then stop).
- When I press STOP on the slide out control panel OR the Master Control Panel the tape mechanism stops & the pinch rollers retract, BUT the capstans do _not_ stop rotating, unless I press Play on the fascia twice, and/or turn off the power.
I assume that you are asking about the capstans? I’m not familiar with the BC5500, but on other Beocords the capstan turns whenever the deck is not in standby. Glitch
Thanks @Glitch – it looks like what I have then is “normal” for a B&O tape deck. But it does seem strange behaviour to me, and can’t do much for prolonging component wear.
13 April 2023 at 12:52 #45613Glitch
BRONZE MemberBut it does seem strange behaviour to me, and can’t do much for prolonging component wear.
For some bearing technologies, the highest wear occurs when the mechanism starts. I think that this is because motion is needed to create and maintain an oil film. Bearing wear is negligible after the bearing reaches equilibrium. B&O probably made this design decision in order to minimize wear.
Glitch
13 April 2023 at 20:13 #45614Dillen
ModeratorIt wears out the motor brushes instead.
Anyway – your deck acts normally.Martin
13 April 2023 at 21:58 #45615Glitch
BRONZE MemberIt wears out the motor brushes instead.
Good point. The brushes certainly wear out (and don’t appear to be a serviceable part).
Glitch
