Home › Forums › Product Discussion & Questions › BeoCord › BeoCord 5500 – Shutting off
- This topic has 8 replies, 4 voices, and was last updated 3 months, 1 week ago by
kknyc.
29 August 2025 at 23:05 #69179
Grgur Pauker
BRONZE MemberHello everyone, I recently acquired a nice BeoCord 5500 in a really good shape. It has only few minor scratches, but I have a issue which I simply can’t resolve no matter what I think of. When I first tried it playing on my Beosystem 2300 + BeoLab 2, tapes were playing in “slow-mo”. I tried playing few of my tapes, which weren’t really kept in some nice enviorment (in the attic full of dust and heat, for the past 15 years), and the problem was persisting.
First thing that came to my mind was the belt issue, since this particular one is from 1987, type 4931. So I ordered belt for the cassette drive. Since I was already replacing that belt, I thought I’ll go ahead and replace the O-Ring used for opening the deck, since it has been 38 years.
Replacing both of these was kind of easy, without any big problems, although there were few screws that got stuck after all those years. Transistors, cables, capacitors, electronics… everything seemed nice to me. There was nothing burnt-like, or some cables that were ripped, or bulging capacitors. After I put it back together I also cleaned pinch rollers and the head. I played some of my tapes and they were playing back perfectly. Although the sound isn’t the greatest because those tapes have seen some better days, they weren’t playing in “slow-mo” anymore. In meantime I also got some well preserved tapes from my friends that were still using them to play music in 2000s, since my father was only buying CDs ever since 1989. Those newer tapes had fuller sound, clear, with noted highs, and with good blasting bass.
The first problem that happened is that sometimes when I use Fast Forward or Fast Rewind function, right pinch roller travels to the capstan, capstan spins itself in place (but does spin not the pinch roller), for a brief period of time of 1-2 seconds, and then BeoCord shuts off and the deck closes, together with BeoSystem and BeoLab which also shut down. When I turn it back on, if I proceed to use the right pinch roller, exact same thing will happened. But when I press “Turn” button and use left pinch roller instead of right, it will work totally normal. This was happening occasionally at the first time, but it got more often, sometimes even after pressing FFW just 3-4 times.
Second issue that showed up after using BeoCord few times, right pinch roller will play tapes like a “DJ”. When I say that I mean that when I use right pinch roller, as the supply reel spins, e.g. 3/4 of its circle it will sound normal (no “slow-mo”, clear audio) and then the rest 1/4 will slow down and sound like slowed version, and so in cycle. When I switch to using the left pinch roller, problem disappears. I’m not sure could it be the supply reel causing this problem, or the pinch rollers themselves, or cassette drive problem, or even some electrical problem.
New pinch rollers for replacement have arrived, but I’m not sure will they resolve the problem. Since Beocord is located in another country where my occasion house is, I won’t be able to take it into my hands until February of 2026. Since I’m collecting tapes and I buy used ones which corespond to the ones I had in the past (but lost or threw them away), this piece of equipment is really of value to me. Any help would be greatly appreciated.
30 August 2025 at 08:07 #69217Dillen
ModeratorIn FF and FR the capstans are not supposed to drive the tape but, depending on the situation and operation,
the tapehead bridge will load (partially) allowing for track sensing.Sounds like the overload circuit is kicking in.
I see this all the time with Ebay belts, particularly from Portugal.
Are the belts correct for this model? Where did you buy?Martin
30 August 2025 at 13:19 #69226Grgur Pauker
BRONZE MemberI have ordered this belt from Amazon from company called “Thakker”. Do you have any better suggestion where should I order the replacement belt from? To me belt was fitting perfectly, not too tight nor too loose.
About overload circuit, I found safety fusible resistor at Danish Sound Parts. Is that the part you mentioned/thought of?
4 September 2025 at 16:27 #69368Dillen
ModeratorDanish Sound Parts can sell you the correct belt(s).
The safety circuit is monitoring the motor load and sends a signal to the processor to shut down the Beocord, if the load is too high.Martin
10 November 2025 at 18:25 #71040 peppsModeratorHi both, just read this with interest.
My Beocord 6500 is also misbehaving. I’ve attached a video of what happens when I use Rew/FF or in this example Auto Record:Oh. Wait. I can’t upload a video.
Well it sounds very similar. The head and pinch roller engage, a ‘painful’ whirring noise comes from the Beocord and the unit shuts down.
And because I have a Beolink set-up the BS6500 shuts down along with the BV7-40 and Beolabs 😄
The Beocord has new belts (a few months old) which I bought from Danish Sound Parts.
Any ideas? And @Grgur Pauker did you find a solution?
Favourite Product: Beosystem 6500
14 November 2025 at 18:47 #71173Grgur Pauker
BRONZE MemberHey pepps,
I’ll be able to take it apart again in April. For now, I ordered all of the spare parts available for BeoCord 5500 on Danish Sound Parts (pinch rollers, belts and resistors). Some of them are for estatical reasons, like rubber feet and tires and PCB holders.
Best,
Pauker
9 December 2025 at 13:15 #71829kknyc
SILVER MemberMy Beocord 5500 is experiencing a similar symptom, new belts and feet from DSP (surprisingly straight forward replacement). I wish I got the roller wheels, I had to reorder
Unfortunately, tape will play side 1 but…
- side 2 volume is muddy and lower
- press [turn] side 2 plays for about 1-3sec. STOP ->Standby
- FF or REW – LEDs show movement, but no tape spin, about 5sec. STOP ->Standby
Also noticed the head travel seems ‘sticky’ doesnt “slide” easily. (I going to go thru the whole Transport area: capstans, head, wheels, with a Qtip and some IPA )
Any suggestions for essentials lubricant and lubrication points? (if any)
31 December 2025 at 05:59 #72224kknyc
SILVER MemberI just got done cleaning the transport module—lots of stick greasy to be cleaned out. Both sides now play and FF RW works but there remains two issues. I hope @Dillen or @Grgur Pauker may have some suggestions…
- How are the Pinch rollers replaced? I got a set of pinch rollers (DSP) for my 5500 Type I, but I’m unsure how to replace them.
- After getting Play and FF and RW working, the output vol is low and muffled. How could I correct this? (I was careful not to touch any settings of the play head, all components look fine/nothing burnt or darkened).
Thanks for any links, info, tips 👍
1 January 2026 at 18:27 #72254kknyc
SILVER MemberHow are the Pinch rollers replaced? I got a set of pinch rollers (DSP) for my 5500 Type I, but I’m unsure how to replace them.
Well, once I had the courage to remove the spring washers on all the spindles everything went smoothly: the rollers were a simple ‘slide pin/insert new wheel’ and all the moving parts/spindles/slides got cleaned and lubricated.
I still have the low level/muddy sound which may need to go to a tech with the tools needed to make height and azimuth adjustments. Can any one recommend a tech in NYC area?
