Home › Forums › Product Discussion & Questions › BeoCord › Beocord 5500 – Drawer falls out. No locking mechanism
- This topic has 8 replies, 4 voices, and was last updated 1 year, 7 months ago by
Dillen.
31 July 2024 at 15:13 #57801
Erik Notini
BRONZE MemberHello all!
I have a Beocord 5500 that I bought second-hand in the hope of being able to repair it. One of the issues with it is that the large Drawer doesn’t seem to have a latch when it is closed. If you lift it slightly at the back, the tray slides out.
I have opened it up and noticed that the drive belt for the Drawer is a bit loose. However I can’t imagine that it would have any impact on whether the drawer locks or not in closed state.
I haven’t tried replacing any drive belts yet because I want to know if my problem is solvable or not before doing so
Has anyone had a similar issue and knows where the locking mechanism is located? I have twisted and turned it, but I haven’t been able to figure out what is supposed to keep the tray closed
Hope anyone can help me!
Best regards
ErikAttachments:
You must be logged in to view attached files.1 August 2024 at 18:05 #57892Die_Bogener
BRONZE MemberHello Erik,
the Beocord 5500-7000 has no lock system. This behaviour is quite normal, no defect.
1 August 2024 at 19:28 #57900Erik Notini
BRONZE MemberHi Martin!
Thank you for the quick response!
Now I know that I shouldn’t look for something that doesn’t exist atleast!Do you know if there is anything that can be done to fix the problem, or is it completely hopeless, do you think?
Best regards
Erik2 August 2024 at 13:54 #57911Die_Bogener
BRONZE MemberThe gear box and the linear slide had a special silicon grease. This grease is very stiff and used as a damping stuff, making smooth and slow movements.
The problem: after 30 years it can be like cement or glue. I’m used to remove it and clean it, since it is hard to get and dependend on the temperature. Sometimes the drawer did not open any more.
Sometimes there was so much force, that the gearbox wheel was broken.
The gearbox can be adjusted between light and somewhat little more more heavy slide. But this means that the mainboard must be lifted out of the drawer … i do not recommend removing this board. It can break easily.
4 August 2024 at 20:11 #57996Erik Notini
BRONZE MemberHi Martin and thanks again for your reply!
I have already taken everything out of the unit.
Is this the part I should lubricate, and can I use this grease?
You write that it is possible to adjust the gearbox between light and heavy.
How do you do this? Do you mean that you adjust it by how much grease you apply, or do you adjust it in some other way?Best regard
Erik5 August 2024 at 17:47 #58022Glitch
BRONZE MemberErik,
The drawer is primarily held in place by the belt and drawer motor. The motor’s resistance to turning, along with the mechanical advantage of the belts and pulleys, keeps things in place. One can still open the drawer manually by back-driving the motor. I would start debugging this by replacing the belt. A loose, slipping belt would result in the behavior that you are describing.
Glitch
6 August 2024 at 17:36 #58050Erik Notini
BRONZE MemberHi Glitch, and thank you for your comment!
I have ordered a new belt along with some other parts.
I will post an update once I have everything installed.Thanks again, everyone!
Erik
7 August 2024 at 08:37 #58080Die_Bogener
BRONZE MemberThere is a linear gear and inside is a sliding pin on the drawer. There you can use this silicon grease.
The axle is not so good, since i have seen that the torque can open the axle and the axle becomes loose. And a loose axle usually ends in a broken wheel…
The gearbox has one fixing bolt and is adjustable …
10 August 2024 at 12:42 #58130Dillen
ModeratorThe damping grease is a bit too thick for this.
The action will be smooth, but the timing may not allow for complete opening and closing.I use this stuff for the large gear and the four rollers (practically every place where plastic works against metal):
https://www.dksoundparts.com/product/grease-for-carriage-metal-rails-etc/
