Home › Forums › Product Discussion & Questions › BeoCord › Beocord 4500 Disassembly
- This topic has 1 reply, 2 voices, and was last updated 3 years, 10 months ago by
pepps.
12 May 2022 at 05:20 #34771
Katigburgers
BRONZE MemberHello, I have a beocord 4500 that would not play cassettes so was hoping I could change the belt. I ordered a replacement but am having issues removing the top to access the motor. Does anyone have a service manual that shows disassembly? The only one I found had a schematic. I managed to remove the bottom plate and the control panel, but am not sure how to remove the top. Doesn’t seem as easy as other models that simply lift up like a car hood. Any help or tips would be greatly appreciated!
12 May 2022 at 08:23 #34772 pepps
ModeratorHello there,
To remove the top you need to power the unit and open the lid, leave it in the up or open position. Then power down.
To the left and right corners of the inside of the lid are 2 little plastic tabs. One at a time gently lift each little tab and carefully start to slide the lid up and off.Then check all screws are removed from the rear and you should be able to lift the rear of the plastic cover and carefully slide it away from you and off.
Take care with all the internal plastics. I’ve changed belts on Beocord 3500 models and found plenty of brittle and breakable plastic pieces inside.
Julian
(Martin from this site has a good paper guide for belt changes on Beocords)
Favourite Product: Beosystem 6500
