Home Forums Product Discussion & Questions BeoCord BeoCord 2000 (292x) plastic washer?
Viewing 7 posts - 1 through 7 (of 7 total)
  • #71390
    pl212
    SILVER Member
    I’ve successfully replaced the pinch roller, belts, and rubber rollers in my BeoCord 2000 with DKSoundParts’ excellent kits.  After reassembly I noticed this clear plastic disc or washer in my work area, and can’t figure out where it might have come from.  I’ve looked through the service manual and can’t find an obvious candidate either.
    Always possible it’s not supposed to be there — this deck had been repaired once before in the 1990s and it might have dropped in there while on that workbench…
    I’ve photographed it with a pen for scale… thanks for any ideas!
    CharlieWednesday
    GOLD Member
    I’ve repaired maybe three of four Beocord 2000s, and I don’t recognise that washer.  That’s all I can offer though!
    pl212
    SILVER Member
    Thanks, that’s reassuring 🙂 In other washer-related notes, it’s interesting how there are both front and back black (cardboard?) washers for the two screws that secure the heat sink. The ones on the outside back of the machine are easy enough to get right, but I’m guessing the interior ones were constantly lost. (I found both of mine lurking in the bottom tray of the BeoCord…)
    pl212
    SILVER Member
    I was watching a video about the BeoCord 2000 and happened to catch where the transparent washer should go… I had tried this myself but found it to be a tight fit so I didn’t force it. Turns out (at least according to this video) the tension is on purpose to keep the capstan in place – and perhaps to prevent any lubricating oil from seeping upwards?
    • This reply was modified 3 months ago by pl212.
    Thomas Wisinski
    It’s the washer that keeps the capstan on
    #73183
    pl212
    SILVER Member
    Yes, thank you — glad I went back to put that back in! 🙂
    I have since found that you can get bulk packages of these in various random sizes by looking for “Audio Lock Plates” on eBay.  As always they ship from China, and surely many of the kinds are not useful, but I figured they are so easy to lose I should have some spares for the next deck I repair…
    Dillen
    Its job is to stop lubricants from creeping up the capstan to the tape.
