Home › Forums › For Sale & Wanted › Wanted › Beocord 1200 R2R Wall bracket
- This topic has 4 replies, 3 voices, and was last updated 11 months, 4 weeks ago by
Van Jensen.
2 October 2023 at 08:03 #49434
MrRoastBRONZE MemberAs the title says I’m looking for a wall mounting bracket for a Beocord 1200 – apparently they all came with one as standard (so the user manual says!).
5 October 2023 at 16:09 #49435 mexkingBRONZE MemberChecked the manual, you should be able to make one yourself its simple but considering the weight and that plastic over years gets brittle I wouldn’t trust the small pegs on the bottom cover of the 1200
8 October 2023 at 12:05 #49436 MrRoastBRONZE MemberThat’s my concern also – I have the wall bracket for the Beomaster 1200, however, the base of that is metal, not plastic like the Beocord.
26 March 2025 at 16:21 #64735 Van JensenSILVER MemberHi MrRoast,
I made myself a wall bracket from a small alloy profile – you can find the dimensions on the photo below.
Best vJ
You must be logged in to view attached files.My B&O Icons:
26 March 2025 at 16:22 #64737 Van JensenSILVER MemberP.S. dimensions in mm 😉
