Home › Forums › Product Discussion & Questions › BeoCom › Beocom 2 joystick broken
- This topic has 4 replies, 2 voices, and was last updated 2 years, 8 months ago by
Hiort.
15 February 2023 at 10:47 #43852
HiortGOLD MemberIs it possible to remove (a few) of the buttons on the keypad, in order to glue back the joystick that has broken?
28 June 2023 at 10:15 #43853dinyavin
BRONZE MemberHi Hiort, yes it is possible to remove buttons. you need to put something flat(corner of credit card for example) below the button and just push it upwards – from the bottom of the phone in to the direction of the screen. And it will click off. The same other way round to put it back.
Hope, I explained it understandable way =)
28 June 2023 at 12:30 #43854 HiortGOLD MemberThanks,
I skipped the phone in the end. Its lying dead in a drawer….
28 June 2023 at 12:38 #43855dinyavin
BRONZE MemberWhat version do you have? Are you interested in selling it?
28 June 2023 at 15:55 #43856 HiortGOLD MemberIt’s a blue Mk1. Battery is new but I think the guy that helped me to install it did not do a good job. So it may need some more love.
