Home › Forums › Product Discussion & Questions › BeoCenter › Beocentre 2200 platter/flywheel not level
- This topic has 12 replies, 2 voices, and was last updated 2 years, 3 months ago by
Dillen.
10 December 2023 at 12:51 #51147
chrisexile
BRONZE MemberGood morning! My first post, hope everyone is well?
I have a beocentre 2200 which has been working lovely for the last couple of years but recently there seems to be an imbalance and I’m hoping it is an easy fix? Doesn’t look like anything has snapped etc but as you can see from the attached video, there is a slight tilt which causes the platter to scrape.
any ideas on how to fix this please?thanks in advance, Chris
10 December 2023 at 15:55 #51148Dillen
ModeratorHas the center bearing come lose from the base plate?
10 December 2023 at 18:38 #51149chrisexile
BRONZE MemberThanks Dillen- is that this part? Or underneath it maybe? If so, how would I fix that please?
10 December 2023 at 19:19 #51150Dillen
ModeratorThe “skeleton” sub-platter can be lifted off.
That would ease inspection.Martin
10 December 2023 at 19:32 #51151chrisexile
BRONZE MemberThank you but that section seems to be locked in by 3 brackets and has the belt wrapped around it?
apologies, you can probably tell my knowledge is low! Thanks 🙂10 December 2023 at 21:20 #51152Dillen
ModeratorThe three locks must be rotated a little using a wide-bladed screwdriver, enough to allow
the subplatter to pass.
They will usually move in “loud chunks”.The belt will come off, and you may have to take off the black plastic surround to get at the
motor pulley to put it back (renew it and the motor mounts while in there).Martin
11 December 2023 at 00:21 #51153chrisexile
BRONZE MemberThank you! Will take a look at that 🙂
Chris
11 December 2023 at 16:10 #51154chrisexile
BRONZE MemberHi. So this has been resolved as the circled part was not fully released.
i do now have a slight brushing sound – could that be down to needing a new belt perhaps?Video attached
chris
11 December 2023 at 19:29 #51155Dillen
ModeratorThe scraping sound could come from the belt rubbing on something.
If you run the deck without the platter, the belt could run on the subplatter flange.Or it could be from the record sensing mech.
Have you tried with a record on the platter?Martin
12 December 2023 at 15:25 #51156chrisexile
BRONZE MemberHi
seems like a possible belt issue? Videos attached.
thanks
chris
12 December 2023 at 17:22 #51157Dillen
ModeratorThe interesting video is the bad one. I simply can’t see if the belt scrapes on something
– or the motor pulley, it can also scrape on the motors metal bracket (bad motor mounts).Martin
12 December 2023 at 17:57 #51158chrisexile
BRONZE MemberSorry which video please? Neither are great to be honest! Ha
when I play without a record it only spins for a couple of seconds.
chris
13 December 2023 at 07:55 #51159Dillen
ModeratorThe interesting video is the one where you (should be able to) see the belt running its path.
“when I play without a record it only spins for a couple of seconds.”
That’s normal. It won’t play without a record but needs to spin the platter to check for one.Martin
