Home › Forums › Product Discussion & Questions › BeoCenter › Beocentre 2000 turntable removal
- This topic has 4 replies, 3 voices, and was last updated 8 months, 2 weeks ago by
James Rawnsley.
24 May 2025 at 20:28 #65791
James Rawnsley
BRONZE MemberHi all, I’ve recently acquired a Beocentre 2000 which I’m in the process of servicing. Ive come to a standstill unfortunately.I can’t work out how to remove the turntable and the service manual doesn’t help. I’m sure I’m missing something really obvious. I think I’ve got all the screws out.Any help would be very much appreciated.Thanks in advanceJames25 May 2025 at 16:15 #65811Lorenz Hilf
BRONZE MemberFor me pressing down on one end of the turntable makes the other end come up, so that I can grab it. Also I have the same Beogram 2000 5821 and I have troubles with the tone arms up and down movement. Does yours move freely up and down when playing? Could you send me a video of the tonearm mechanism? Specifically the „black box“ which holds the end of the tone arm? Thanks in advance
26 May 2025 at 14:43 #65825James Rawnsley
BRONZE MemberThanks for your reply. At the moment the tape deck and radio are out of the unit so I can’t do any videos but I do have issues with the height of the tone arm and it skating across records. I suspect the small screw next to the pivot may be there for adjustment but until I can get the whole top cover off I can’t be certain.27 May 2025 at 22:12 #65852Jason
BRONZE MemberHi
I have a Beocenter 2000 in mint vgc condition with speakers. I am looking to sell this on to another enthusiast or collector. I am not used to this forum so contact me on 07974209231 or via email mccartan311@btinternet.com
Favourite Product: Beocenter 2000
Signature: I have a mint condition Beocenter 2000 with speakers. That is available to anyone who wants it for an agreeable price.
07974209231My B&O Icons:
6 July 2025 at 22:35 #66836James Rawnsley
I finally got the platter off. The trick is to drop it on the side from about 6 inches 🤣.
So the platter is held on by 3 small pieces of double sided tape. Once it’s off you can access all the screws to gain access to the mechanism.
I wouldn’t recommend dropping it, I did it by accident but at least it solved the problem.
