Home › Forums › Product Discussion & Questions › BeoCenter › Beocenter 9500 turns off
- This topic has 7 replies, 5 voices, and was last updated 2 years, 6 months ago by
Die_Bogener.
18 August 2023 at 12:32 #48311
harmster
GOLD MemberHello everyone,
I am the proud owner of a beocenter 9500 and used it daily for years. Now it wont turn on anymore, well it will bit immidiatly shuts off (volume lowers and then switches off). Ive unplugged every cable and I think its broken. Is anyone familiar with this problem? I want it repaired. It served me well and deserves to be repaired. I live in the Netherlands if anyone has an contact per chance?
18 August 2023 at 13:09 #48312 KolfMAKERBRONZE MemberMaybe BeoBuddy can help you (Utrecht area).
If you look for his name, you can send him a PM.Location: The Netherlands
18 August 2023 at 16:52 #48313Die_Bogener
BRONZE MemberThe BC9500 is similar to the 7000 system… and 5500/6500/7000 amplifier have a problem with the potentiometer of the “no_load_current”.
If it fails, the current is so high, that the emergency cutoff is activated.
Replace the pots, around 100 Ohm… measure the adjustment of the pots, remove them, replace them… start around with the same position of the pots… take FOTO !
The 7000 uses this adjustment… it’s 7000, not 9500. But very similar…
18 August 2023 at 18:25 #48314Dillen
ModeratorThe BC9500 is similar to the 7000 system… and 5500/6500/7000 amplifier have a problem with the potentiometer of the “no_load_current”. If it fails, the current is so high, that the emergency cutoff is activated. Replace the pots, around 100 Ohm… measure the adjustment of the pots, remove them, replace them… start around with the same position of the pots… take FOTO ! The 7000 uses this adjustment… it’s 7000, not 9500. But very similar…
Replace the trimmer and adjust according to the service manual!
Referring to a defective component makes no sense.Do the other channel as well, as it will also fail sooner rather than later.
18 August 2023 at 20:43 #48315 BeobuddyGOLD MemberAll of the above is good advise when it indeed is about the BM7000 and former series with their discrete build amplifiers.
The BC9500 has a simplified amplifier consisting a STK module without the idle and offset trimmers.
The reason the BC9500 shuts off is most off the time caused by voltage on the output due to a malfunction in the powersupply or defective STK module.
19 August 2023 at 13:18 #48316Die_Bogener
BRONZE MemberYou are right, there is the protection unit with TR201/202 and TR401/402 against DC voltages on the output…
28 August 2023 at 08:23 #48317harmster
GOLD MemberSorry for the late reply. Ive been on holiday. I am not very familiar with the electronics. Is it feasible to get it repaired and if so, is it doable to do myself or should I find someone?
Thanks in advance.
28 August 2023 at 08:51 #48318Die_Bogener
BRONZE MemberHmmm, yes. It is better to find someone, since it is not so easy to open the system. The BC9500 has a lot of bolts and parts…
You have a voltmeter?
Check the output with no signal with and without connected speakers. AC and DC voltages… left and right… muted and nonmuted…
Tell us the reading.
