Home › Forums › Product Discussion & Questions › BeoCenter › Beocenter 9500 sound problems
- This topic has 14 replies, 5 voices, and was last updated 2 years, 6 months ago by
Epic B and O.
12 September 2023 at 08:21 #48897
Epic B and O
BRONZE MemberI have a question. I have a pair of Beolab 6000 from the 90s connected to my Beocenter 9500, and I have noticed that both speakers sound muffled.
I’ve bought new 8pin dins and there’s no difference. Is there a fault in the 9500 I need to look out for, or is it possible the drivers on the 6000 have gone at the same time?I connected my Penta’s to the 9500, and they seem ok.
Any help would be greatly appreciated
Best regards
13 September 2023 at 09:46 #48898 filip_kbhBRONZE MemberTake off the fret and inspect the speakers. Quite sure that they need a refoam job which is quite easy.
13 September 2023 at 14:00 #48899Epic B and O
BRONZE MemberThank you for your help.
Yes I did notice that one of the speakers drivers had a split in the foam, but would that cause both speakers to sound muffled?
13 September 2023 at 14:03 #48900Epic B and O
BRONZE MemberThe cables between the Beocenter and Beolab are new, but I’ll check the sockets for the 8 pin din cables.
I did connect my Penta speakers to the Beocenter, and they sounded ok
13 September 2023 at 17:24 #48901 filip_kbhBRONZE MemberWhoever did that refoaming job should have left it to somebody else. Besides the excess of glue, it even looks like the speaker cone is not touching the rubber surrounds. If the other speaker looks anywhere near this, I can totally understand that you would not get the expected sound results.
13 September 2023 at 17:37 #48902Dillen
ModeratorI agree.
13 September 2023 at 22:27 #48903Epic B and O
BRONZE MemberYes it wasn’t done by a professional unfortunately.
I will order new drivers off eBay. My only concern is the part numbers don’t exactly match. The one’s on eBay are 8480232, and mine is 8480239
14 September 2023 at 10:09 #48904 filip_kbhBRONZE MemberWhy don’t you just order new foam surrounds and do the job properly? It really isn’t complicated to do. Cut of the old misalligned surrounds and rinse of the glue with isopropyl alcohol. Order new foam surrounds from a certain store in Holland and do the job properly.
14 September 2023 at 14:46 #48905Epic B and O
BRONZE MemberCan you recommend a good quality foam kit?
I live in Australia
14 September 2023 at 15:41 #48906Glitch
BRONZE MemberEpic,
I suggest that you try to remove the old surrounds and glue before ordering replacement surrounds. You may end up fatally damaging the driver cones, depending on the glue used and your skill at removing the olds parts. This also opens up the possibility of ordering surrounds that will conceal any flaws left from the previous work.
I would also be very careful with using any solvents. They can have unintended consequences. When they work, they can work very well. When they don’t, it can be a real mess. Small test areas are the prudent way to proceed.
Glitch
14 September 2023 at 23:23 #48907Epic B and O
BRONZE MemberMany thanks for your help mate
15 September 2023 at 04:42 #48908 trackbeoBRONZE MemberAlso notice the existing surrounds were made up of two half-circles pasted together — must not have had the correct diameter on hand. You can see the seams at 9:00 and 3:00. And it looks like two (2!) repair efforts were made, given different colors of dried glue.
So I hope somebody can tell you if the part number substitution buying whole drivers is OK. Best choice given that mess. But if not, read on…
[Edit: Before wasting time on foam, double-check with an ohmmeter that the speakers are about the same resistance. A reading of infinity (open, split wire) or of zero (short, fused wire) is obviously bad, and not worth wasting more time on. Nobody mentioned this prior because it’s really unlikely, but given that photo, anything is possible!]
As to the solvents, what you use will depend on how crummy the glue from previous attempts turns out to be. First try up to 91% isopropyl alcohol, and a long fingernail is the finest tool you have or will need. Failing that, a stronger solvent, like “denatured alcohol” or (USA) Goof-Off™, don’t get the stuff on your skin — you should probably use the *back* edge of an X-Acto knife straight blade (actually a triangle). The blade would cut the speaker cone, but the squared-off rear usually catches the glue without ripping into the driver.
If the previous attempt was particularly horrible, the driver might be ruined anyway. Once you remove the old foam, examine the remaining, probably now jagged, edge versus the overlap of the new foam. Also follow the instructions with the re-foam kits to press/piston in&out to make sure the driver coil isn’t rubbing against the magnet or frame before you waste time gluing. Not sure why being coy about where to order parts from Holland, but here in the USA: https://www.simplyspeakers.com/bang-olufsen-speaker-repair-foam-edge-kits.html (International shipping might be expensive, but the basic parts are cheap.)
15 September 2023 at 23:48 #48909Epic B and O
BRONZE MemberThank you for your help mate.
To be honest I think I’ll just buy new drivers. Had these speakers since the 90s, and want them to sound like new.
One thing I noticed which I’ll recheck later, was that there wasn’t much sound coming from the tweeters. If there’s a n issue with them, that would also explain the muffled sound.
I’ll check the 8pin din sockets also16 September 2023 at 16:33 #48910Glitch
BRONZE MemberI will order new drivers off eBay. My only concern is the part numbers don’t exactly match. The one’s on eBay are 8480232, and mine is 8480239
If you can’t find drivers with the exact same part number, try to at least get a replacement with the same impedance. They probably will not sound the exactly that same as stock, but something with the same impedance has a much better chance at sounding OK than something with a different impedance.
Glitch
21 September 2023 at 15:26 #48911Epic B and O
BRONZE MemberOrdered 4 new drivers from Austria.
Hopefully this fixes the muffled sound.
Another thing I noticed was that the tweeters would occasionally cut out. I’ve checked the connections, and they all seem ok.
