Home › Forums › Product Discussion & Questions › BeoCenter › Beocenter 9500 FM issue
- This topic has 1 reply, 2 voices, and was last updated 3 years, 10 months ago by
spassmaker.
12 May 2022 at 09:38 #34773
ks4hw
BRONZE MemberUnit tunes high end of FM band above 104 when inputting lower frequency such as 99.9 attempts to tune then jumps to 104.6. Using search won’t find any stations below 104. Direct input goes to selected frequency then jumps back to 104.6.
16 May 2022 at 12:22 #34774 spassmakerBRONZE MemberHi
Try to reset the RAM ( all FM Stations will be deleted, sound options will be set to zero) with the “TESTMODE” function.
How to get this testmode and reset RAM is discribed in the service manual chapter 7-10.
For me it helped quiet often if the behavior of the Beocenter is somekind “abnormal”
Let us know if you got success
Regards
Christian
