Home › Forums › BeoWorld around the world! › Deutsche › Beocenter 9300 MUTE function not working
- This topic has 7 replies, 4 voices, and was last updated 1 year, 1 month ago by
pepps.
9 February 2025 at 19:10 #63634
Stefan CologneBRONZE MemberHello dear community,
I’m in the process of restoring a Beocenter 9300 and I’m almost done. Now I’ve noticed that the “MUTE” function doesn’t work. When I press the “MUTE” function on my Beolink 1000 or directly on the BC, I hear a click (a relay picks up, I would say) in the system, but the volume does not go to “MUTE”. The volume buttons otherwise work perfectly. Does anyone have an idea what it could be?
Greetings!Stefan
Favourite Product: Beocenter 9300
10 February 2025 at 09:12 #63658 peppsModeratorHello Stefan,
If you plug headphones in do the speakers mute?
Julian
Favourite Product: Beosystem 6500
10 February 2025 at 21:36 #63684 Stefan CologneBRONZE MemberHi Julian,
thanks for your E-Mail.
No I plugged in my B&O Form 2 Headphones 😉 and the speakers dont mute if i push the Mute-button but the red Mute-Light switchs on like normal. But the sound in the earphones and loudspeakers is still on.
Stefan
11 February 2025 at 06:35 #63686 lausviSILVER MemberIf you are using passive speakers; are they connected to the Speaker 1 outputs? If they are in Speaker 2 they won’t mute (by design).
11 February 2025 at 13:33 #63691 peppsModerator11 February 2025 at 15:39 #63694Dillen
ModeratorThat’s because speaker set 1 is meant for local use – in the same room as the Beocenter.
Speaker set 2 is typically routed to linked systems in other rooms, where they are muted locally – and independantly.Martin
12 February 2025 at 18:28 #63721 Stefan CologneBRONZE MemberLausvi,
Martin-Dillen,
Julian-Pepps,
Iam really sooooooooo stupid. After all the soldering work and some heart attacks I used the wrong Speaker outputs. Sorry! Now its working as it should 😉
Have a gerat evening!Stefan
12 February 2025 at 21:09 #63736 peppsModeratorExcellent! Enjoy your Beocenter 😍😍😍😍🍾🥳
