Home › Forums › Product Discussion & Questions › BeoCenter › Beocenter 9300 cassette deck noise
- This topic has 2 replies, 2 voices, and was last updated 3 years, 2 months ago by
opirat.
7 January 2023 at 08:39 #42633
opirat
BRONZE MemberHi, my beocenter 9300 cassette deck it works well for the first 10 minutes, than it starts to make like a mouse noise very bothering. If I stop it, the noise goes on. Any suggestion? Thanks, Luigi
9 January 2023 at 01:19 #42634 peppsModeratorHave you tried different cassettes? Some of mine are squeaky as they play.
Julian
Favourite Product: Beosystem 6500
9 January 2023 at 11:04 #42635opirat
BRONZE MemberThanks for your suggestion. I tried with different cassettes. It seems to be always the same: it works for few minutes, than the “mouse” starts. If I stop the cassette, the noise goes on. To stop it, either I switch to another source, or I switch the Beocenter off. As soon as I can I will try to lubricate the motor bearings as suggested on the thread. Any suggestion to do that? Thanks you all, Luigi
