Home › Forums › Product Discussion & Questions › BeoCenter › Beocenter 9000 RCA Connections to Beolab 6000’s (left channel is low)
- This topic has 1 reply, 2 voices, and was last updated 10 months, 2 weeks ago by
multicare.
8 May 2025 at 20:15 #65499
Snipboy
BRONZE MemberI am attempting to connect my Beocenter 9000 to Beolab 6000’s with RCA cables. I noticed the right speaker/channel sounds like it has normal volume, but the left speaker/channel sounds much more faint. Is there a setting or switch to correct this so they both sound the same?
TIA!
Favourite Product: Beocenter 9000
16 May 2025 at 15:52 #65659 multicare
GOLD MemberYou could check to see if the balance on the BeoCenter 9000 is correct.
If set too far to one side you would have a similar issue.My B&O Icons:
