Home › Forums › Product Discussion & Questions › BeoCenter › Beocenter 9000 motors slow
- This topic has 7 replies, 6 voices, and was last updated 2 years, 3 months ago by
pepps.
28 May 2022 at 11:07 #35106
brianlaing
GOLD MemberHello all!
I got a donor amplifier / power board from Denmark to replace the faulty on I have in the US.
I now have regular audio but have noticed that while the CD player works fine, the doors and the cassette are slow. The doors don’t open or close all the way (a relay towards the back shuts the motors down) and the cassette sounds about 1/3 too slow.One other thing – when I installed the donor / amp board there was no power to the cassette or door motors I noticed that there was a T1A fuse missing from the donor board I pulled one from the original board (checking it first to make sure it worked) and the audio came on as it should I tested the other fuse and it was fine. Just mentioning this since the fuses are fine on the board. Muting works fine too
Any thoughts on why the motors seem to be slow (they were fine with the previous amp/power board)?
28 May 2022 at 23:55 #35107 Mark-sf
BRONZE MemberI would check the 7V power supply section around TR19 and C10. If the fuse that was bad was T1A for the 5v supply there may be and issue with IC4 circuit or its zener.
29 May 2022 at 01:12 #35108brianlaing
GOLD MemberThanks for the tip! I actually decided to locate the parts on the original board (the one that controls the motor speeds correctly but only sound when you turn it up all the way). I noticed a missing resistor! So, tomorrow I’ll replace the missing resistor and swap back in the original board. Worth a try!
6 June 2022 at 19:12 #35109brianlaing
GOLD MemberActually the missing resistor wasn’t the issue. In the original board the same resistor was removed, so not a coincidence. What ended up being the issue was a loose connector on a capacitor. The trace had lifted from the board for one of the legs on the capacitor, so I just added a jumper wire. Problem solved. The doors and cassette motors work at the proper speed. Always seems like something minor. 😉
29 December 2023 at 15:08 #35110johnparker99
BRONZE MemberI have the same problem with CD motor going slowly. Tape door motor is good. Do you recall where you found the loose connection @brianlang ?
29 December 2023 at 16:51 #35111Dillen
ModeratorLubricate motor bearings.
Replace belt.
Clean door tracks.Martin
31 December 2023 at 09:11 #35112auric
BRONZE MemberPCB 60 which is the board mounted across the heat sink on the back of the unit.
There is one connector with a pair of wires. P80 or P81. Those powers the motors.
The traces on that PCB are very thin and fragile. Lots of cold solder joints and cracked/peeling traces especially where the connectors terminate and speaker muting relay.
Reflow the connectors and make sure the traces are not cracked.
5 January 2024 at 11:01 #35113 pepps
ModeratorActually the missing resistor wasn’t the issue. In the original board the same resistor was removed, so not a coincidence. What ended up being the issue was a loose connector on a capacitor. The trace had lifted from the board for one of the legs on the capacitor, so I just added a jumper wire. Problem solved. The doors and cassette motors work at the proper speed. Always seems like something minor. ?
Fantastic well deduced!
Favourite Product: Beosystem 6500
