Home › Forums › Product Discussion & Questions › BeoCenter › Beocenter 7700 back panel stuck
- This topic has 2 replies, 3 voices, and was last updated 2 years, 7 months ago by
Dillen.
24 August 2023 at 05:36 #48421
Beomaster 7700
BRONZE MemberHi everyone. The back panel of my Beocenter 7700 is not rotating up. I need to replace the belts on the cassette deck and cannot access the screws that allow the unit to be opened up. Do not want to force it. It seems to be locked. Any advice appreciated.
25 August 2023 at 04:05 #48422 Mark-sfBRONZE MemberBy back panel are you referring to the black grill that covers the connections? If you are it is only held by gravity. There is a stop piece attached to the underside in the middle of the grill piece that might have gotten stuck down.
25 August 2023 at 13:47 #48423Dillen
ModeratorBy back panel are you referring to the black grill that covers the connections? If you are it is only held by gravity. There is a stop piece attached to the underside in the middle of the grill piece that might have gotten stuck down.
The black grill (with sockets etc.) is held down by a plate-type bronze spring.
Just pull up. It’ll snap free.Martin
