Home › Forums › Product Discussion & Questions › BeoCenter › Beocenter 7700
- This topic has 3 replies, 2 voices, and was last updated 3 years, 3 months ago by
Dillen.
19 December 2022 at 05:32 #41575
tedrecord
BRONZE MemberMy beocenter 7700 tape has been repaired, this required a part being glued together so it may stop at any time. The question I need answered is the tape mechanism the same as the beocenter 7007.
Tedrecord
19 December 2022 at 16:05 #41576Dillen
ModeratorYes, the tape mechanism is the same, but keep in mind that the tape controller
and the tape drive has been calibrated together.
If you replace only the tape mech, you must realign everything on the tape controller to match the new tapeheads etc.
Best is to keep the things paired and replace both the drive and the controller.
– Or repair your drive. What has broken?Martin
1 January 2023 at 10:29 #41577tedrecord
BRONZE MemberMartin
Thank you for the reply. I have just returned from holiday. Happy New Year. I purchased a beocenter 7002 for a good cartridge for a turntable I have. The tape deck on my 7700 is working , however, a part on the tape device has been repaired (glue, picture in original post) and I want to salvage that part if the decks were compatible for when the deck eventually stops. May work for ever.
Ted
1 January 2023 at 15:15 #41578Dillen
ModeratorThe original bracket for the flying idler was black.
The last original replacements were white – as the one pictured, and they are known to break.Martin
