Home › Forums › Product Discussion & Questions › BeoCenter › beocenter 7007 RECORD PLAYER SPINNING VERY VERY FAST
- This topic has 4 replies, 2 voices, and was last updated 20 hours, 34 minutes ago by
Dillen.
24 September 2025 at 04:28 #69871
stylianos panagopoulos
BRONZE MemberRecently my beocenter started to have an issue with the record player , it spinns very fast without corecting the speed if i press 33 or 45 , i put it on service mode and measured the pins of the motor wires while i had pressed the turn button , it runs on 13,7 volts!! any suggestions? is the turntable board faulty?
24 September 2025 at 07:49 #69873stylianos panagopoulos
BRONZE Memberbeocenter 7007 RECORD PLAYER SPINNING VERY VERY FAST
24 September 2025 at 09:28 #69875Dillen
ModeratorSomewhere wrong with the motor circuit apparently. Perhaps missing feedback from the motor?
Did you check the speed setting trimmers?Martin
24 September 2025 at 09:33 #69878stylianos panagopoulos
BRONZE MemberGoodmorning , thank you Martin for your responce , i did check the trimmers moved them anti-clock wise but nothink reduced the speed , the motor is 3 v but i measured 13.5 on the pins in motors socket while i had pressed the turn button
24 September 2025 at 16:45 #69879Dillen
ModeratorCheck for cracked solder joints – especially where connectors are soldered into PCBs.
Check also the supply voltage to the motor control circuit.Martin
