Home › Forums › Product Discussion & Questions › BeoCenter › BeoCenter 7000 turntable cover hinge Or spring holder
- This topic has 2 replies, 2 voices, and was last updated 1 year, 5 months ago by
guileukow.
15 October 2024 at 16:00 #60165
guileukow
BRONZE MemberHi All,
I had the same issue on my Beocenter 7007 turntable hinge that was continuously falling like described in this archived thread: https://archivedforum2.beoworld.org/forums/t/37193.aspx
It’s not a question that I have but more an answer to those looking for a solution, hence I’m launching this topic for the record.
I made a 3D model that you can print to address this issue:
https://www.thingiverse.com/thing:6794011
It’s not too difficult to assemble everything back together but you need to be cautious and not focus too much on the spring.
Hope this helps!
16 October 2024 at 08:16 #60183Dillen
ModeratorAvailable in polycarbonate, injection molded :
https://www.dksoundparts.com/product/beocenter-5000-7000-7002-spring-holder-for-turntable-dust-cover/Martin
16 October 2024 at 08:32 #60188guileukow
BRONZE MemberThanks Martin! Knowing this would have saved me couple of hours especially since I placed an order recently to them for the capacitor kit of my S45-2, so if I knew it before I would have ordered it too 😅.
Thanks!
