Home › Forums › Product Discussion & Questions › BeoCenter › Beocenter 7000 Cassette – No Audio, Just Rumble
- This topic has 1 reply, 2 voices, and was last updated 2 years, 2 months ago by
Dillen.
1 February 2024 at 02:21 #52551
mjcallo
BRONZE MemberI am hoping someone may be able to assist. I picked up Beocenter 7000 along with the SC-70 cabinet in Rosewood. The turntable, receiver, and external inputs all work great. The cassette deck was not functioning. I replaced the belts, which had turned to sticky black goo.
The mechanism of the cassette is now functioning perfectly. At first I had audio from the left channel and just a loud hum from the right channel. A little later, I had no audio signal. Instead, there is just hiss or rumble. It is as if it is picking up the movement of the tape across the head but not the audio information.
Any suggestions are welcome!
1 February 2024 at 07:35 #52552Dillen
ModeratorCould be a bad relay.
There are two, found on the large tape controller board under the turntable.Martin
