Home › Forums › Product Discussion & Questions › BeoCenter › Beocenter 3500 belt
- This topic has 3 replies, 3 voices, and was last updated 1 year, 4 months ago by
David Appleton.
26 November 2024 at 12:42 #61156
David Appleton
BRONZE MemberHi
I had a Beocenter 3500 which I tested worked OK (it was my late fathers). All was fine, I gave it to my son but as soon as we tried it, the belt came off. He ordered a new one but the same thing happens. Any advice very welcome, thank you!
26 November 2024 at 13:08 #61158 AdamSBRONZE MemberDid you order the belt from Danish Sound Parts (formerly Beoparts)?
If not, then I wouldn’t necessarily trust it to be correct!
26 November 2024 at 19:03 #61165Dillen
ModeratorLosen the three transport screws. They are found under the platter.
With the transport screws tightened for transport the belt will almost always come off when the motor is started.
The same goes for Beogram 1203, Beogram 2000, Beogram 3000.Martin
30 November 2024 at 15:28 #61238David Appleton
BRONZE MemberThank you! We will give it a try
