Home › Forums › Product Discussion & Questions › BeoCenter › Beocenter 2200 Tone arm lowering problem
- This topic has 1 reply, 2 voices, and was last updated 2 hours, 36 minutes ago by
Lorenz Hilf.
31 October 2024 at 19:08 #60614
Ördög
BRONZE MemberGreetings!
I’m having some trouble with my Beocenter 2200. The tone arm doesn’t lower enough to make contact with the vinyl.
The counterweight is set correctly and when I took the player apart and fumbled a bit with the plastic pieces with a spring attached, the tone arm started to move correctly. The thing is that this wasn’t a permanent fix and the tone arm again doesn’t lower enough to play.
Here’s a pic and a video from the part I mean. In the video the tone arm works correctly.
You must be logged in to view attached files.25 May 2025 at 16:11 #65810Lorenz Hilf
BRONZE MemberI have the same Problem. The pastic Box seems to block the tonearm from moving freely up and down. Have you managed to solve the issue?
