Home › Forums › Product Discussion & Questions › BeoCenter › Beocenter 2200 Lid Replacement
- This topic has 1 reply, 2 voices, and was last updated 6 months, 2 weeks ago by
Dillen.
16 September 2025 at 22:01 #69714
James Singer
BRONZE MemberHello, would anyone be able to tell me how to remove the plastic lid on a Beocenter 2200? Mine has a crack in it and I want to replace it, but I’m struggling to see how to get the plastic lid unscrewed from the hinge?
Many thanks!
24 September 2025 at 09:25 #69874Dillen
ModeratorYou need to take off the whole rear piece with the hinges etc.
Then you remove the two small plastic covers under the lid to reveal the screws.
Ask at Danish Sound Parts if you need a replacement cover, they may very well have a good used one in stock.Martin
