Home › Forums › Product Discussion & Questions › BeoCenter › beocenter 2200 Driver belt installation
- This topic has 1 reply, 2 voices, and was last updated 3 years, 5 months ago by
Mark-sf.
31 October 2022 at 08:01 #40339
jigglydiggly
BRONZE MemberHello, my belt snapped, cant figure out how to install the belt. Where does the belt go?
Usually on other turntables you just pull the lid off , but this one seems more complicated…
Do I need to take the whole thing apart? Screwed off all the “C” screws, but the turntable still won’t come off, do I need to unscrew all the “A” screws as well?Also is the size of the belt important, someone told me I could just glue the belt together at the breaking point…
31 October 2022 at 17:30 #40340 Mark-sf
BRONZE MemberThe platter lifts off to replace the drive belt. You need the right one which is available from beoparts.com.
