Home › Forums › Product Discussion & Questions › BeoCenter › Beocenter 2200
- This topic has 2 replies, 2 voices, and was last updated 2 years, 11 months ago by
si_wallace.
22 April 2023 at 09:48 #45939
si_wallace
BRONZE MemberHi. I recently inherited my fathers 2200 and it plays beautifully. But the turntable makes a ticking noise which is very evident when playing a quiet record. B&O tech in Barcelona tell me they cannot fix due to parts not being available. Any guidance? Thank you.
22 April 2023 at 14:28 #45940Dillen
ModeratorWhat parts are not available?
Check if the motor bushing touches the metal bracket.
If it does – replace the motor mounts.
https://www.beoparts-shop.com/product/motor-suspension-rubber-bushing-grommet-f-several-beogram-beocenter-models-2/If the motor itself is noisy, it must be taken apart and repaired (most can be)
– or replaced, and a good condition used original motor would be the way forward in that case.Martin
22 April 2023 at 17:09 #45941si_wallace
BRONZE MemberThank you. I will investigate.
