Home › Forums › Product Discussion & Questions › BeoCenter › Beocenter 2 LED flashing red
- This topic has 3 replies, 2 voices, and was last updated 11 months, 3 weeks ago by
YannChris.
14 April 2025 at 11:33 #65129
Dimo Dimo
BRONZE MemberDear all,
I have a Beocenter 2 that is connected to Beolab 3 speakers and a Beolink System.
When I connect the Beocenter 2 master and socket unit, the master unit LED flashes red but the screen does not turn on.
Neither pressing the remote nor touching the control panel of the device has any effect.
When I connect it to the Beolink system, all speaker and IR receiver LEDs turn on (red) but nothing changes on the master unit.I could only find that the flashing LED might indicate an error, but not which one.
Any advice for solutions or troubleshooting?
Many thanks in advance!
Best,Dimo
14 April 2025 at 19:20 #65136 YannChrisGOLD MemberHi,
The blinking red LED usually means that the PIN code has to be entered.
Regards,
Y.
14 April 2025 at 20:48 #65137Dimo Dimo
BRONZE MemberThanks YannChris, makes sense, but usually it should show something on the display while blinking, shouldn’t it?
Best,
Dimo
14 April 2025 at 20:51 #65138 YannChrisGOLD MemberYou are right, it should.
