Home › Forums › Product Discussion & Questions › BeoRemote › Beo5 & Beo6 › Beo5 Config Tool – how to remove a zone
- This topic has 2 replies, 2 voices, and was last updated 2 years, 1 month ago by
Stefan Zueger.
7 January 2024 at 11:25 #51992
Stefan Zueger
GOLD MemberI toyed around with my Beo5 Config Tool and accidentally added a zone which I do not really need. Actually I need just one zone, and that one is called “Main”.
Would anyone know how to remove the 2nd zone I added but do not need?
Thank you very much, Stefan
Favourite Product: Beosound 9000
8 January 2024 at 18:14 #51993 StoobieGOLD MemberFirst of all you need to make sure there are no “products” in the zone you want to remove, then go to the zones tab, right click on the the zone you want to to delete and the option to delete should be in that list.
Stoobie
9 January 2024 at 22:20 #51994 Stefan Zueger
GOLD MemberFirst of all you need to make sure there are no “products” in the zone you want to remove, then go to the zones tab, right click on the the zone you want to to delete and the option to delete should be in that list. Stoobie
Thank you very much, Stoobie!!
