Home › Forums › Product Discussion & Questions › BeoRemote › Beo4 and beolink converter 1611
- This topic has 4 replies, 3 voices, and was last updated 3 years, 7 months ago by
Anonymous.
1 September 2022 at 03:41 #38790
ruben1975
BRONZE MemberHello, I purchased a beolink converter 1611 to use it with my beolab 3500. How do I get the beo4 to communicate with the converter? and after that with to ajust the sound settings on the beolab? I read different manuals (masterlink handbook, beolink handbook, converter manual) but a bit difficult to understand, I have to programm the beo4?
1 September 2022 at 04:17 #38791 Millemis
BRONZE MemberIf I understand your question right…..
You don’t!
The 1611 was created to convert the old MCL system to the (then) newer ML system.
The BL3500 is a dedicated link speaker that needs a master (audio or video) to be used.
If setup right, you can draw on the sources from e.g. an audiomaster/the sources there (radio/cd……).
You control the BL3500 with the remote – have a look here:
https://www.beoworld.org/prod_details.asp?pid=373
1 September 2022 at 18:53 #38792Anonymous
InactiveHi,
beolink converter 1611 can act as a audiomaster
so you only connect source to it and masterlink between converter and bl3500 and press cd or radio doesnt matter and it should work
1 September 2022 at 19:03 #38793 Millemis
BRONZE MemberSure – but you’ll need to activate and control the 3500 to get sound.
The 1611 can be hidden away once the connection is done.
1 September 2022 at 19:17 #38794Anonymous
InactiveHi, yes of cource ts need the beo4 to the beolab 3500
but i maybe missunderstand ts
