Home › Forums › Product Discussion & Questions › BeoCenter › Beo Converter controls BeoCenter 9500
- This topic has 27 replies, 7 voices, and was last updated 2 years, 3 months ago by
Bart99.
22 December 2023 at 18:53 #51237
Bart99
BRONZE MemberOK thank you for the information. Then I have to look for this device.
PS All the best to all forum users in the New Year 2024
and a peaceful Christmas.
29 December 2023 at 17:56 #51238Bart99
BRONZE MemberHello, gentlemen, fantastic information, after the purchased purchase, as Guy wrote “Beo Converter 1611 along with the Audio Aux Line ‘bad. The device began to work;)
Most of the control is great, above all, control of the CD player. It is possible to spin the songs. It is also possible to control the “Tape” cassette player and the “Phone” turntable, which was very surprised by “Tape2”.
Unfortunately, there is a big minus, I do not have the option to enable the analog FM radio. This foundation is not shown in the application, although it is set.
The second minus, as Caropla wrote, unfortunately cannot be controlled by connecting speakers directly to the BeoCenter9500. After starting the Beo 9500 device, the “Mute” button turns on and the speakers on the Beo9500 do not turn on. This is the only minus, because on the amplifier I have a sound like bass, trabs, and you can’t control these settings, despite the active speakers. Of course, you can turn on these voters from a dedicated remote control, but it was about getting rid of Beo Remote.
Thank you all for helping you have fun on New Year’s Eve.
29 December 2023 at 18:06 #51239Bart99
BRONZE Member29 December 2023 at 19:03 #51240 carolpaBRONZE Memberdid you check the box for BEO9500 Radio on the Experience mapped to NL page?
My Beomaster 7000 Radio source is shown; see below!note: the difference to your system and mine: I do have additional NL devices and the Beosystem 7000/BLC combo is set as “connect to (primary)” to a BS35. So as mention before, maybe you’re confronted with BLC limitations.
30 December 2023 at 22:50 #51241Bart99
BRONZE MemberYes, I have the RADIO box selected.
I specially took a screenshot because the name of the NL function is different from that performed by BEO9500.At the same time, I show the NL settings screen. In my case, it is possible to set only PRIMARY, because after expanding there are no other options, the field is empty.
31 December 2023 at 00:56 #51242LukeS
BRONZE MemberHave you got an IR eye attached to your beolink converter? If not I’d set the ir option to 0 and see if that helps (equivalent to a video master in option zero)
2 January 2024 at 21:01 #51243Bart99
BRONZE MemberHello, I do not have an IR eye connected to the Beolink converter.
Unfortunately, I cannot set it to 0 (photo), possible settings are 1,2,4.I noticed that after unchecking the options: A.MEM, A.AUX, N.RADIO, the TV tab disappeared in the application.
Best regards
2 January 2024 at 21:03 #51244Bart99
BRONZE MemberI noticed that after unchecking the options: A.MEM, A.AUX, N.RADIO
the TV tab disappeared in the application. I’m writing if anyone is interested. -
