Home › Forums › Product Discussion & Questions › BeoGram › Beogram CD-50 – Lower Disc Holder 9132
- This topic has 30 replies, 3 voices, and was last updated 9 months ago by
Rob Bune.
2 June 2025 at 19:51 #66139
Madskp
GOLD MemberI decided to fix the spindle motor and for now it looks like a succes for me
I did a writeup in my other thread about it https://forum.beoworld.org/forums/topic/boegram-cd50-carrige-slow/#post-66138
2 June 2025 at 20:36 #66142Rob Bune
BRONZE MemberThat’s great news!
Which tool are you using to take the grub screw out of the brass spindle to remove the motor? I am trying various small screw driver but none seem to bite. One did wok on the other grub screw on the cam nut.
2 June 2025 at 20:50 #66143Madskp
GOLD Member1.3mm allen key worked for me
2 June 2025 at 21:09 #66146Rob Bune
BRONZE MemberI’ve order one – before I round off the grub screw!
3 June 2025 at 08:44 #66153Madskp
GOLD MemberBe sure to measure the distance between the spindle and the metal plate above before unscrewing it. I have noted a lot of comments in other threads that the distance shown in the service manual is not correct, so better to make it the same as it was.
12 June 2025 at 09:48 #66318Rob Bune
BRONZE MemberBad news – I accidently touched the CD mechanism on the PCB to the right that you turn the mechanism over to.
It took out the main fuse – but now the spindle motor doesn’t spin at all – I’m not sure where to begin troubleshooting this one!
12 June 2025 at 15:26 #66324Madskp
GOLD MemberSounds bad. What about the carrige Mechanism will that still operate? Just tobtry to isolate the issue
12 June 2025 at 15:47 #66325Rob Bune
BRONZE MemberOnly the tray will close and raise the disc, nothing on the mechanism. I need to troubleshoot the psu.
3 July 2025 at 09:59 #66762Rob Bune
BRONZE MemberOk so I was lucky, it was just a blown fuse that I had to replace. I went down a rabbit hole though checking voltages on the board and after a few days I realised that the micro-switch which activates the spindle motor when the mechanism closes and raises was not making and so the voltage wasn’t being sent to start the motor! I must have bent before I shorted the boards.
So with new fuses it all seems ok, I had fine tune the brass knob on top of the main cam – too tight and mechanism wouldn’t raise reliably, too loose and it wouldn’t raise the disc into place high enough. I found that it helps to tighten the grub screw even when testing because the knob can move if it meets any resistance meaning that it is not in the position that you think it was when set.
It’s been an adventure – learned a lot but happy to pass this back to my friend. Now to restore the donor player that I bought 🙂
3 July 2025 at 11:11 #66764Madskp
GOLD MemberGood to hear that the issue was only a fuse 🙂
The brass knob “tuning” indeed seems to be very important. On my CD50 it was also glued into position besides being hold by the grub screw, which indicates the importance of it’s position.
Hopefully your donor player will be a walk in the park to restore now that you have the experience from this one
3 July 2025 at 12:05 #66768Rob Bune
BRONZE MemberYes I was sure to add some Lock-tit glue to the knob as well as tightening the grub screw.
The donor player will have its own challenges, it is quite dirty so I will strip it entirely to clean and remove some rust from the chassis 🙂
