Home › Forums › Product Discussion & Questions › BeoVision › Bang & Olufsen MX6000 CRT TV Image jumps
- This topic has 0 replies, 1 voice, and was last updated 3 years, 2 months ago by
Martin.
Viewing 1 post (of 1 total)
24 January 2023 at 02:50 #43297
BRONZE MemberI have a Bang & Olufsen MX6000 that has a fault that the image randomly jumps.
It’s an early one made for the Italian market
Type: 35/04 MTI SW1.2Using an ESR meter I tested all electrolytic capacitors on the power supply and deflection board and I found five bad ones. They where all the same brand and rating 470uf 16V.
I thought that replacing the bad caps would of sorted the problem, but no difference.
Here is a video of the fault: https://youtu.be/hWppZPKIPA8
If anyone knows what the problem might be any help would be appreciated.
Cheers,
Martin.
