Home › Forums › Product Discussion & Questions › BeoGram › Bang & Olufsen Beogram CD 5500 – Reading issue only on the first tracks
- This topic has 3 replies, 2 voices, and was last updated 1 year ago by
Dillen.
19 January 2025 at 16:22 #62892
bo_bod
BRONZE MemberHi everyone,
I recently acquired a Beogram CD 5500 player. After a few repairs to the DIN cable, which did not appear to be original (short circuit on the data wire), I also replaced infamous cap C2103. The player “works,” except for reading issues:
The CD starts playing normally without any rubbing noise, the number of tracks is displayed, but the first tracks are choppy and skipping a lot. The tracking seems to try to reposition itself a lot. However, as soon as the middle of the CD is reached, there are no more reading issues.
What are the different things to test, and especially how to check:
- The press plate seems unlikely: it doesn’t rub against anything but seems to vibrate a lot; even when I manually re-center it to reduce vibrations, problem persists Is the motor not spinning fast enough?
- Is the optical block not following the movement well in the center of the CD?
- The CDM block’s suspension? Where can I find replacements, or did anyone try to 3D print them?
- The motor’s suspension?
- Other ideas ?
Thank you for your insights, and sorry for the automatic translation which may look a bit awkaward 🙂
21 January 2025 at 19:01 #62970Dillen
ModeratorWhat brand and type of capacitor did you fit for C2103?
Did you do any adjustments? – If not DON’T do any.Drive supports here.
No, you cannot 3D-print these. There are more to them than meets the eye.Martin
23 January 2025 at 14:01 #63020bo_bod
BRONZE MemberHi thanks, I’ll look into the replacement supports. I may try some 3D printed or home made solution as an experiment and will keep everybody posted.
Regarding the cap C2103, I replaced with a random chinese one with same values I had laying around, I know there is a lot of discussion especially in a French forum about using an original one but thought it was a pedantic discussion … I kept the original and will refit it if ESR and capacitance values are still spot on.
Edit : Cap c2103 it was tested : 37µF with ESR 6 Ohm so I guess it is toasted !
24 January 2025 at 12:12 #63046Dillen
Moderatora pedantic discussion …
It’s not!
The discussions didn’t come out of nothing.Get the proper parts.
