Home › Forums › Product Discussion & Questions › BeoVision › Avant NG LCD Panel
- This topic has 2 replies, 2 voices, and was last updated 2 years, 2 months ago by
prorsum.
10 January 2024 at 10:01 #52081
prorsum
BRONZE MemberHi there,
I read that the Avant non-NG uses a Samsung LTA550FJ01 LCD panel. But which ones does the NG use?
And if you replace a panel, is it a simple matter of plugging in a new one, or does there some sort of programming need to happen (ignoring the fact that it might need some calibration).
Thanks for your help.
11 January 2024 at 10:22 #52082Anonymous
InactiveHi
Avant 55NG use LTA550FJ04
Programming thru servicetool for calibration
needed for correct picture
15 January 2024 at 15:59 #52083prorsum
BRONZE MemberThank you for the info. Sadly I couldn’t find any other TV which also uses this exact panel.
The Philips 55PUS8809 seems to have a LTA550FJ01.
Maybe they are intercompatible ?
