Home › Forums › Product Discussion & Questions › BeoVision › Avant 85″ – different types.
- This topic has 6 replies, 3 voices, and was last updated 2 years, 7 months ago by
Ravsted.
5 August 2023 at 11:36 #48105
ZeroCool
BRONZE MemberHi all,
I am looking at 3x different types of the Avant 85″ TV – does anyone know the difference?
- Type 8870 (1860500)
- Type 8686 (1860408)
- Type 9687 (1857408)
Many thanks,
5 August 2023 at 15:54 #48106 Keith SaundersBRONZE MemberType number 8686 and 9687 are the same UK product.
I don’t know what Type 8870 is, but it is not an AVANT 85
5 August 2023 at 18:31 #48107ZeroCool
BRONZE MemberDo you know the differences between the 8686 & 9687?
Attached is the sticker off the back of the type 8870.
5 August 2023 at 18:33 #48108ZeroCool
BRONZE MemberWrong photo – try this one 🙂
6 August 2023 at 13:12 #48109 Keith SaundersBRONZE MemberThe sticker images in each posting you made look the same to me…
The type 8870 must I assume be a later version..
7 August 2023 at 10:39 #48110ZeroCool
BRONZE MemberThat is what I tink (it’s a later version) – do you know where I can see what the differences between the 3x versions are?
7 August 2023 at 16:58 #48111 RavstedBRONZE MemberBeovision Avant was released in 2014
I believe the 85″ version came end of 2014 … Maybe a bit later.
The NG (New Generation) came in 2016.
As you picture says NG – Type 8870 must be the New Generation type.
The NG runs on same platform as Beovision 14 i.e. Android TV. The NG works with BeoRemote 1 BT (Bluetooth instead of IR)
If I google ‘Beovision Avant label’ I see that type 8679 is first generation.
Hope this information helps a bit.
