Home › Forums › Product Discussion & Questions › BeoVision › Avant 55 Over the Air Antenna
- This topic has 3 replies, 3 voices, and was last updated 2 years, 5 months ago by
Chasp.
30 October 2023 at 02:23 #49961
Chasp
BRONZE MemberI would like to know how to install an over the air antenna to my Avant 55, since it does not have a coaxial input. Also, I can’t find a selection for antenna in any of the menu options.
30 October 2023 at 16:04 #49962 trackbeoBRONZE MemberSorry, if you’re in the USA, you probably already guessed: you don’t. Connect a TiVo Edge for Antenna (or an old TiVo Roamio OTA) via HDMI to the Avant. Other countries are different, some even including a dual tuner with a USB recording drive! The 3 coaxial F-connectors, if you had them, would be at the top above the Ethernet jack (Satellite 1, Satellite 2, Antenna).
30 October 2023 at 16:22 #49963 MillemisBRONZE MemberI would like to know how to install an over the air antenna to my Avant 55, since it does not have a coaxial input. Also, I can’t find a selection for antenna in any of the menu options.
Could it be that your Avant is a no-tuner version?
30 October 2023 at 17:32 #49964Chasp
BRONZE MemberThank you. It’s a U.S. version. Looks like I will be going through the HDMI input on the top row of the tv.
