Home › Forums › Product Discussion & Questions › BeoGram › Arm on Beogram 5000 worn’t move down
- This topic has 3 replies, 3 voices, and was last updated 2 years, 2 months ago by
Tagelsir1663.
28 January 2023 at 10:50 #43401
ChrDH
BRONZE MemberHi all
After moving house I finally got around to setting my Beosystem 5000/5500 up again. For the first days my Beogram 5000 (the radial arm version) worked just fint, but after unplugging the system from the mains and plugging it in again it suddenly worn’t lower the arm onto the record when pressing play, as if the servo have blown or something. it just hovers above the spinning record.
Is this common, and what may the problem be?
Best regards
Christian
29 January 2023 at 19:28 #43402 Mark-sfBRONZE MemberThe easiest first check is to make sure your counterweight has not moved. Is the arm able to go down by adding more tracking force?
15 February 2023 at 21:07 #43403ChrDH
BRONZE MemberHi
I tried adjusting the weight, it does not make any difference but the arm is able to go down if pushed slightly with a finger.
22 January 2024 at 15:19 #43404 Tagelsir1663BRONZE MemberI have the same problem, it happened all of a sudden, frustrating.
