Home › Forums › Product Discussion & Questions › BeoGram › Are Bang & Olufsen Beogram RX2 and TX2 platters interchangeable?
- This topic has 2 replies, 2 voices, and was last updated 11 months ago by
kevin berezansky.
29 January 2025 at 08:31 #63182
kevin berezansky
BRONZE MemberThe radial surface design seems the same. Are they exactly the same? Moreover, is it easy to exchange them?
29 January 2025 at 13:53 #63194 B&O OrlandoBRONZE MemberYes, I have both. One was in better condition than the other and I swapped them.
13 February 2025 at 07:28 #63766kevin berezansky
BRONZE MemberHow easy is it to swap them? Do the platters simply lift off?
