Home › Forums › Product Discussion & Questions › BeoRemote › Apple Tv 4k swipe up with beoremote one
- This topic has 2 replies, 2 voices, and was last updated 3 years, 11 months ago by
scanorama99.
6 April 2022 at 03:50 #33961
scanorama99
BRONZE MemberI have not yet found a way to manage this. Is this not possible?
I am usingt the ir-eye extension cable from my beovision avant 55, mk1.
My main tv networks provider where I can see all my national tv channels use swipe up on the apple remote to flip up a list of all the channels at the bottom of the picture (when watching live tv), then I can click left/right to quickly choose another channel. But I need the apple remote now all the time just to switch channels.
Has anyone been able to solve this? I am basically prepared to cancel my subscription to choose another tv provider if I can not get this to work 🙂
9 April 2022 at 23:53 #33962
FrogGOLD MemberI suggest you write a note to B&O support. The appletv remote PUC is really based on the non-touch remote and, as such is very limited in functionality. They could add this function as a long-press option on the up button for instance.
I suspect you’d get a lot of appletv users happy to see the new remote supported.
12 April 2022 at 17:11 #33963scanorama99
BRONZE MemberYep I asked B&O and apparently they have checked this but they said the swipe command uses bluetooth and not IR. And I asked if it would help if I get the bluetooth version of the beoremote one but they said it wont help.
I tried to connect an old non-swipe-compatible apple tv remote but the swipe requirement on the tv channel switch was still there. Perhaps their apps are using this as standard when they recognize they are installed on an apple tv 4k since that remote can use swipe.
I guess I could go back to the old non-4k apple tv but then I will not get 4k screen which would be a downgrade on the avant that has great 4k ability.
I really like that my current setup with floor stand only has a single white power cable going down from the avant. The apple tv is hidden inside the back of the tv. I have been thinking about trying chromecast. I saw the ultra version had 4k. Anyone have any experience on this or any similar?
