Home › Forums › General Discussion & Questions › General Discussion & Questions › Apple TV 4K Settings
- This topic has 22 replies, 9 voices, and was last updated 2 years, 3 months ago by
Millemis.
17 December 2023 at 16:55 #51061
Vedet
BRONZE MemberThank you, Sandib!
I have figured out, as it seems to me, this issue. The problem is that Simon Weir mistakenly referred to the modification of the HDMI cable as UHD 2, created specifically for eARC. In fact, we are talking about an Ultra-high-speed HDMI cable, called UHS, which has Generation issue No. 1 and No.2. So, the Gen No.2, was created specifically for eARC. Therefore, Simon Weir’s mistake is that he wrote UHD 2, but he should have written UHS 2, then everything becomes logical and understandable.
I have only one question left – which of the brands, manufacturers is the leader in the production of HDMI cables in order to purchase a decent quality cable?
17 December 2023 at 18:23 #51062Sandyb
BRONZE MemberThank you, Sandib! I have figured out, as it seems to me, this issue. The problem is that Simon Weir mistakenly referred to the modification of the HDMI cable as UHD 2, created specifically for eARC. In fact, we are talking about an Ultra-high-speed HDMI cable, called UHS, which has Generation issue No. 1 and No.2. So, the Gen No.2, was created specifically for eARC. Therefore, Simon Weir’s mistake is that he wrote UHD 2, but he should have written UHS 2, then everything becomes logical and understandable. I have only one question left – which of the brands, manufacturers is the leader in the production of HDMI cables in order to purchase a decent quality cable?
Indeed, my assumption was that UHS 2 was the intention – I’m not aware of anything such as UHD 2 or whatever it even means.
But it’s pretty clear, a certified Ultra High Speed cable is all you need. My installer put in the cables for me, so I cant remember the brand – but the idea of the the certification is that anything with that certification will be fine. I wouldn’t over think which brand to get to be honest.
17 December 2023 at 18:37 #51063 MillemisBRONZE Member -
