Home › Forums › BeoWorld around the world! › Dutch › Albumcover in Beomaster?
- This topic has 4 replies, 3 voices, and was last updated 5 months, 3 weeks ago by
Joris Allewijn.
31 August 2025 at 12:57 #69246
Joris Allewijn
BRONZE MemberHi, does anyone have a solution to add and display covers in maps on the Beomaster5? I could not find earlier topics on this. Greetz, Jos
Favourite Product: Beosound 5
31 August 2025 at 15:58 #69250 TignumGOLD MemberHi Joris, see maybe this thread: https://archivedforum2.beoworld.org/forums/t/46773.aspx
I am sure there are more threads that you can find by hard googling :-). Using a tag editor can help you out. Album cover images should not be too large.
Let us know your progress!
Regards,
Johan
1 September 2025 at 13:10 #69271 carolpaBRONZE MemberHi Joris, see maybe this thread: https://archivedforum2.beoworld.org/forums/t/46773.aspx
Regards,
Johan
Niet te groot = max. 1000*1000 pix
1 September 2025 at 18:48 #69290Joris Allewijn
BRONZE MemberThanks everyone, I will try this out and let you know the progress!
Regards,
Joris
3 September 2025 at 20:53 #69344Joris Allewijn
BRONZE MemberI am using EZ Meta Tag Editor now.
It is very easy to add covers in the Metadata. Just double click on a music map, it is imported in this app. Then you click on ” search for cd meta-data. Automatically searching in GD3, WMP, MusicBrainz and Discogs. The album art will be embedded in all the music files in the map.
Works brilliantly.
Thanks for the workaround,
Regards,
Joris
