Home › Forums › Product Discussion & Questions › BeoMaster › Adjusting treble, bass and balance on Beomaster 5000
- This topic has 7 replies, 3 voices, and was last updated 3 years, 2 months ago by
JMK.
15 January 2023 at 03:26 #42867
JMK
BRONZE MemberHi
I have recently bought a Beomaster 5000 and hooked it up to my Beovox S45 speakers and Philips 677 turntable. The sound is a little flat and I want to adjust the bass and treble, but it seems as it can only be done from the Master Control Panel 5000. I have tried to push the ‘neutral’ button which helped a bit, but i would like a bit more bass and maybe a little less treble – especially when listening to records. Is there anything to do other than buying the Master Control Panel 5000?
Thank you in advance
15 January 2023 at 06:25 #42870 Tignum
GOLD MemberWelcome to the forum JMK. There seems to exist a ‘converter’ according to this older beoworld thread: https://archivedforum.beoworld.org/forums/p/12394/92008.aspx. Not sure if that device would also translate Beo4 or BeoLink 1000 tone adjustment signals. The manual found here does not mention tone adjustment. https://beo.zone/media/files/Bang-Olufsen-Beomaster_5000-Owners-Manual-2.pdf.
I think Matador gives the best advice.Regards, Johan
15 January 2023 at 06:57 #42874JMK
BRONZE MemberWelcome to the forum JMK. There seems to exist a ‘converter’ according to this older beoworld thread: https://archivedforum.beoworld.org/forums/p/12394/92008.aspx. Not sure if that device would also translate Beo4 or BeoLink 1000 tone adjustment signals. The manual found here does not mention tone adjustment. https://beo.zone/media/files/Bang-Olufsen-Beomaster_5000-Owners-Manual-2.pdf. I think Matador gives the best advice. Regards, Johan
Thanks! It doesn’t seem to support tone adjustment. Maybe I should just buy the MCP5000
15 January 2023 at 18:13 #42868 matadorModeratorNo. Only MCP5000.
15 January 2023 at 18:24 #42869JMK
BRONZE MemberA Terminal 5000 can’t be used?
15 January 2023 at 18:36 #42871 matadorModeratorA Terminal 5000 can’t be used?
A far as I know Terminal is only for daily operation like source selection and volume control.
15 January 2023 at 18:37 #42872 matadorModeratorThere seems to exist a ‘converter’
Didn’t remember that one! Thanks Tignum.
15 January 2023 at 18:52 #42873JMK
BRONZE MemberAll right, thank you, Matador
