Home › Forums › Product Discussion & Questions › BeoGram › Adapting Ortofon OM-Series for SP Turntables – Small Batch Coming Soon
- This topic has 8 replies, 4 voices, and was last updated 10 months, 3 weeks ago by
Territorial_.
14 October 2024 at 12:19 #60134
Territorial_BRONZE MemberHi everyone,
I thought I’d share a little update on a project I’ve been working on recently. I’m developing a production-quality adapter for SP-connected turntables, specifically for the Ortofon OM series cartridge. The goal is to create an adapter that matches the exact geometry and tracking force specifications of the OM series, with a tracking force between 1.5g and 2g.
I’ve designed the adapter to require only minimal modifications to the original turntable, making it easy to install while maintaining the authentic feel of the equipment. I’ve been testing it on Beogram 1202 and 3000 turntables, and the design follows the original style, including a transparent needle holder.
I’m not sure if this is the right place for a project like this, but I thought I’d share it here to gauge interest. I’m planning to produce a small batch of 10-20 units to start with. If you’re interested, feel free to reach out via private message
– I’ll be gathering a list of those who would like to be notified or involved.
Edit: I will add images when we get the final production-quality housings out.
24 October 2024 at 13:46 #60422
M J VinkSILVER MemberHi, I buy , restore and sell a lot of Beograms roundbelts so maybe I am interested, my name on the internet is Beovintage.
24 October 2024 at 15:58 #60424 CharlieWednesday
GOLD MemberI’m afraid I don’t really understand this. Do you plan to make an adapter that allows the use of Ortofon cartridges in B&O turntables?
24 October 2024 at 16:34 #60425
Territorial_BRONZE MemberYes, you understood correctly. I’m designing an adapter that allows Ortofon’s OM series cartridges to be used with B&O’s SP series turntables, specifically models like the 1202 and 3000, and similar ones with an aluminum tonearm. This only requires minimal modifications to the turntable.
As for the project status, I’ve already tested the first prototypes and confirmed that the mounting and weight adjustments work well. I’m currently refining the final design for the transparent part, ensuring it also provides proper support for the cartridge and the needle assembly.Here’s couple quick renders of the product.
24 October 2024 at 16:37 #60426 CharlieWednesday
GOLD MemberThat is great news. I have three B&O turntables (Beogram 3000, 8500 and RX2), and I’ve replaced the MMC4s in the first two at quite some cost quite recently. They sound great, but the ability to get rebuilt MMC cartridges won’t last forever, so it’s good to see someone working on a longer-term solution. Great work.
24 November 2024 at 12:15 #61123
Territorial_BRONZE MemberThe painting is complete, and I successfully matched the tonearm’s original color. Now, I need to work on the tip section. Currently, it’s painted in the same aluminum color, but I want it to be transparent.
We tested printing with clear filament, but the results were slightly cloudy. Next, I’ll try wet-sanding the clear part’s surface and applying a couple of coats of clearcoat. Hopefully, this will achieve the desired result.
Here’s a quick teaser shot, adapter design vs the original.
What do you think? Any feedback on design?
24 January 2025 at 22:11 #63064
Territorial_BRONZE MemberI’m excited to announce that the Ortofon OM cartridge adapter for SP-compatible B&O turntables is now ready!
This adapter is designed specifically for Ortofon OM5 cartridges and is compatible with models like the Beogram 1202 and 3000. It follows the original specs for geometry and stylus pressure (1.5–2g) while requiring only minimal modifications to your turntable. The design also replicates the original aesthetic, including a transparent stylus holder.
I’ll be producing a limited batch of around 5 units, so if you’re interested in purchasing one, feel free to send me a message.
https://vimeo.com/1050185784/64000f2530
25 January 2025 at 06:23 #63067
NoidBRONZE MemberHi Territorial
can you pm me with some more info on this, and perhaps the price.
3 February 2025 at 09:00 #63344
Territorial_BRONZE MemberI was thinking about the pricing of 140€ for the adapter, wires and weight + cartridge + shipping
You can pick the cartridge type you want from the Ortofon website.So for example, with
OM 5S 185€+Shipping
OM 5E 195€+Shipping
Super OM 5E 225€ + ShippingFor the price its plug and play kit. includes everything.
I have adapters ready but it takes about 5 days to receive the cartridge after I know which type you’re interested in.
