Home Forums Product Discussion & Questions BeoGram Adapting Ortofon OM-Series for SP Turntables – Small Batch Coming Soon
Viewing 13 posts - 1 through 13 (of 13 total)
  • #60134
    Territorial_
    Hi everyone,
    I thought I’d share a little update on a project I’ve been working on recently. I’m developing a production-quality adapter for SP-connected turntables, specifically for the Ortofon OM series cartridge. The goal is to create an adapter that matches the exact geometry and tracking force specifications of the OM series, with a tracking force between 1.5g and 2g.
    I’ve designed the adapter to require only minimal modifications to the original turntable, making it easy to install while maintaining the authentic feel of the equipment. I’ve been testing it on Beogram 1202 and 3000 turntables, and the design follows the original style, including a transparent needle holder.
    I’m not sure if this is the right place for a project like this, but I thought I’d share it here to gauge interest. I’m planning to produce a small batch of 10-20 units to start with. If you’re interested, feel free to reach out via private message
    – I’ll be gathering a list of those who would like to be notified or involved.
    Edit: I will add images when we get the final production-quality housings out.
    #60422
    beovintage
    SILVER Member
    Hi, I buy , restore and sell a lot of Beograms roundbelts  so maybe I am interested, my name on the internet is Beovintage.
    #60424
    CharlieWednesday
    GOLD Member
    I’m afraid I don’t really understand this.  Do you plan to make an adapter that allows the use of Ortofon cartridges in B&O turntables?
    Territorial_
    Yes, you understood correctly. I’m designing an adapter that allows Ortofon’s OM series cartridges to be used with B&O’s SP series turntables, specifically models like the 1202 and 3000, and similar ones with an aluminum tonearm. This only requires minimal modifications to the turntable.
    As for the project status, I’ve already tested the first prototypes and confirmed that the mounting and weight adjustments work well. I’m currently refining the final design for the transparent part, ensuring it also provides proper support for the cartridge and the needle assembly.
    Here’s couple quick renders of the product.
    2
    1
    #60426
    CharlieWednesday
    GOLD Member
    That is great news.  I have three B&O turntables (Beogram 3000, 8500 and RX2), and I’ve replaced the MMC4s in the first two at quite some cost quite recently.  They sound great, but the ability to get rebuilt MMC cartridges won’t last forever, so it’s good to see someone working on a longer-term solution.  Great work.
    Territorial_
    The painting is complete, and I successfully matched the tonearm’s original color. Now, I need to work on the tip section. Currently, it’s painted in the same aluminum color, but I want it to be transparent.
    We tested printing with clear filament, but the results were slightly cloudy. Next, I’ll try wet-sanding the clear part’s surface and applying a couple of coats of clearcoat. Hopefully, this will achieve the desired result.
    Here’s a quick teaser shot, adapter design vs the original.
    What do you think? Any feedback on design?IMG20241124112325
    #63064
    Territorial_
    I’m excited to announce that the Ortofon OM cartridge adapter for SP-compatible B&O turntables is now ready!
    This adapter is designed specifically for Ortofon OM5 cartridges and is compatible with models like the Beogram 1202 and 3000. It follows the original specs for geometry and stylus pressure (1.5–2g) while requiring only minimal modifications to your turntable. The design also replicates the original aesthetic, including a transparent stylus holder.
    I’ll be producing a limited batch of around 5 units, so if you’re interested in purchasing one, feel free to send me a message.
    https://vimeo.com/1050185784/64000f2530
    IMG20250124231206IMG20250124222316
    #63067
    Noid
    Hi Territorial
    can you pm me with some more info on this, and perhaps the price.
    #63344
    Territorial_
    I was thinking about the pricing of 140€ for the adapter, wires and weight + cartridge + shipping
    You can pick the cartridge type you want from the Ortofon website.
    OM Series
    So for example, with
    OM 5S 185€+Shipping
    OM 5E 195€+Shipping
    Super OM 5E 225€ + Shipping
    For the price its plug and play kit. includes everything.
    I have adapters ready but it takes about 5 days to receive the cartridge after I know which type you’re interested in.
    #72457
    Mads Poulsen
    Hi Territorial
    This is a very interesting project! Are you still making these adapters?
    Or does anyone have any knowledge of anyone else selling similar adapters to fit alternative cartridges to e.g. the tonearm of the Beogram 1202?
    Thanks in advance.
    #72458
    Territorial_
    Hi Mads, yes, I’m still making and selling the adapters. At the moment I’ve had some difficulty finding time for the project since I’m building a house. I believe I still have one ready in stock, if I remember correctly.
    #72610
    kknyc
    SILVER Member
    wow this is wonderful, great work! —Wish there was a option for the 5500’s MMC cartridges 😉
    jawad.abbas
    Hi Territorial,
    ​I am writing to you because I am very interested in your ‘plug-and-play’ adapter solution for the Bang & Olufsen SP-series tonearm.
    ​I have a Beogram 1202 and I’m looking for a complete kit (including the modified Ortofon motor and the necessary counterweight/balance adjustment) to be able to use an Ortofon OM-stylus without having to do the assembly myself.
    ​Do you currently have any kits available for sale? If so, the shipping cost to Sweden?
    ​Best regards,
    Abbas
