Home › Forums › Product Discussion & Questions › BeoSound › 9000 Sledge Power Down
- This topic has 1 reply, 2 voices, and was last updated 1 year, 1 month ago by
jacek1313.
7 February 2025 at 15:05 #63518
jacope
GOLD MemberHi all,
I have three BS9000s with the same issue:
When the sledge attempts to move, the whole unit shuts down immediately. Standby LED goes dark and then comes back. Sledge jogs slightly before shutting down. Motor does work when applying 9v directly to it. See video attached.
Any ideas GREATLY appreciated.
You must be logged in to view attached files.My B&O Icons:
9 February 2025 at 12:52 #63616jacek1313
BRONZE MemberI had such a case and the soldering of one of the windings in the engine was damaged. At 9V the engine worked and at a lower voltage it stopped. The LED goes out because the BS9000 resets due to lack of pulses. The engine is quite easy to disassemble.
