Home › Forums › General Discussion & Questions › General Discussion & Questions › 7-40 TV unable to enter OPTIONS via on screen menu
- This topic has 2 replies, 2 voices, and was last updated 1 year, 2 months ago by
Thomas McDonald.
22 December 2024 at 20:29 #61866
Thomas McDonald
BRONZE MemberHi All, I have recently bought a second hand 7-40 tv and although the set and dvd player work I don’t seem to be able to enter into any of the menus to set up the speaker or sound system or other features like the stand position. When I press menu on the beo4, I get play timer coming up with for example DTV SETUP above PLAY TIMER and OPTIONS below it but the cursor will not move between the variables and won’t even enter in the PLAY TIMER menu. Any ideas or suggestions would be very much appreciated!
Tom
Name
Tom McDonald
Sent from Beoworld28 December 2024 at 08:40 #61984 peppsModeratorIs it possible you may have bought a model previously used in a hotel room?
Have you tried contacting B&O customer services with the serial number? Might help.
Favourite Product: Beosystem 6500
28 December 2024 at 11:01 #61985Thomas McDonald
BRONZE MemberThank you for your suggestion. I have since realised that the later version beo4 remote that came with the set had, not as I presumed a missing GO button but, a missing joystick with the navigation feature enabled on the set! Anyway, since managing to disable the navigation feature I can now use my other beo4s!
Thanks -
